Thread: Any Recommendations For Speaker Stands? |
| Posted on Sunday, September 01, 2002 - 11:53 am: |
Have placed an order for the Onkyo 650 and will be needing stands for the front speakers. Although I don't have the speakers yet I know they are about 7.5" wide, a little over 9.5" deep and weigh a little over 12.5 lbs. Can anyone recommend some good, yet not too expensive, stands? I would prefer wood but that is not essential. Right now I am leaning towards the "Wood Technology' stands but thought i'd see what others have done. Any good web sites would also be of help. Thanks. |
Anonymous |
| Posted on Sunday, September 01, 2002 - 10:15 pm: |
It depends on how high up you want them. I bought the Sanus NF30 stands. Very simple yet sturdy design. Made of wood, black. The Onkyo speakers look good on them. You can get them anywhere between $80-100. |
| Posted on Saturday, December 28, 2002 - 12:17 am: |
Get Chicago stands for the fronts and B-Tech BT7 for the rears. |
New member Username: Toe
Post Number: 1 Registered: 12-2003
| Posted on Friday, December 19, 2003 - 01:10 pm: |
Do you think the B-Tech's would work on a ste of M&K 550 and/or 750's? |
New member Username: Spaniard
Post Number: 1 Registered: Mar-04
| Posted on Saturday, March 06, 2004 - 11:55 am: |
i am building myself a stereo stand using technologies to reduce microphonic effects. however, i am having difficulty in locating spikes for the feet of the stands. does anyone know where i can get some? |
Silver Member Username: Hawk
Highlands Ranch,
CO
Post Number: 402 Registered: Dec-03
| Posted on Saturday, March 06, 2004 - 01:18 pm: |
Spainiard: Yes. Look here: http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=48&Object Group_ID=139 Sometimes I swear this place has everything! Good luck! |
Bronze Member Username: Jdsaenz1
Post Number: 38 Registered: Jun-04
| Posted on Monday, June 07, 2004 - 05:25 pm: |
I'm into that 'wood technology' myself! Just spent no more than $15 to build my own. With a top base, bottom base, a 2"x2" post (3ft. in height) painted white to match the room decor, the stands hold the speakers as if they were on display! Hide the speaker wire behind the post, and you're good to go. I thought it would be a bit cheesy, but they turned out pretty nice. Anyway, instead of spending 50 - 100 bucks on speaker stands, I thought I'd save the money to buy movies and such. It's worth a try. |
Bronze Member Username: Lowfront
Post Number: 42 Registered: Jun-05
| Posted on Saturday, June 18, 2005 - 02:38 am: |
I'm in the middle of making these.... Turning out awsome... http://www.tnt-audio.com/clinica/stubby_e.html |
Bronze Member Username: Monstercable
Post Number: 24 Registered: Jun-07
| Posted on Monday, July 02, 2007 - 03:42 am: |
only new members come to this thread? |
