Home > Message Board > Accessories > Remote Controls > Is the Prono worth it?
Author Thread: Is the Prono worth it?
Rob
Its cost a lot. Is it worth it?
Relevant Product Info
mac
Yes it is.Its pretty simple to use and works like a dream.
I would like to control lighting in my home theater. I plan on buying the Pronto remote and it's RF extender. Is there a wall mounted dimmer that will work on the Pronto's RF? Or do you have a better idea, I don't want to point the remote at the wall switch.
Username: Audiophiliac
Boise, ID
USA baby
Post Number: 18
Pronto remotes are great! Lots of support and file sharing. Fairly easy to program. And to answer your question Keith. I think there is a company or 2 that make RF compatible light dimmer. Dont know who off the top of my head. You could always run IR to the switch (cat5e)
the iPronto is slicker than snot but if you really want the ultimate remote...get a tabletPC and Crestron eControl software :P
Username: Toddious
Orlando, FL
I have to be the first to say no...
Pronto's are the old way of controlling. The Universal Remote stuff is much simpler, and user friendly. Also cheaper, with more control.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Accessories > Remote Controls > Is the Prono worth it? [ « Previous ] [ Next » ]
