Thread: Old plug replacement question? |
Stephen A. Smith Unregistered guest |
| Posted on Thursday, July 01, 2004 - 02:34 pm: |
I have an older audio system and the plugs that came with the system are the normal silver plugs. I heard over time the silver plugs loose performance and so I want to upgrade to a gold plated plug. I am wondering to get the sound quality back to where it is suppose to be, do I have to cut off the old plug and connect another or will something like this do just as well? http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5 F007%5F002%5F001%5F004&product%5Fid=274%2D915 Thank you all for the help  |
Post Number: 1009 Registered: Dec-03
| Posted on Thursday, July 01, 2004 - 09:54 pm: |
they loose performance if they get corroded. How old is your system? |
| Posted on Thursday, July 01, 2004 - 11:42 pm: |
From 97 I believe. How do you know if they got corroded? Can you tell visually? |
Post Number: 1016 Registered: Dec-03
| Posted on Friday, July 02, 2004 - 06:31 am: |
Yes, you can tell. What you may want to do is upgrade your cables. and go to 14 gauge speaker wires |
