Thread: Speaker wire to rca |
New member Username: Jasoncourt
Va
Us
Post Number: 1 Registered: Jun-04
| Posted on Sunday, June 27, 2004 - 07:41 pm: |
okay I don't know all my terminoligy but here's my situation. I have a projection tv (toshiba 46h83) that has a single rca input so the tv's speaker can be used as a center channel. My problem doing this is that there is not an output like this on my reciever, only the center channel for my surround sound speakers. Any suggestions? |
Silver Member Username: Project6
Post Number: 968 Registered: Dec-03
| Posted on Sunday, June 27, 2004 - 08:21 pm: |
what does the manual say? i'm sure it will have instructions on how to do this, since it has this capablity. |
Va
Us
Post Number: 2 Registered: Jun-04
| Posted on Monday, June 28, 2004 - 10:54 am: |
you would think the manual would, but no. |
Post Number: 971 Registered: Dec-03
| Posted on Monday, June 28, 2004 - 12:45 pm: |
what you can do is get an RCA cable and cut one end and hook it up to your receiver's speaker output and connect the other end to the TV's RCA connection. Just be careful to check if the TV's speaker can handle the load of the receiver.
