Home > Message Board > Accessories > Cables > Archive through July 23, 2004 > Unable to hook DVD player to TV?
Author Thread: Unable to hook DVD player to TV?
blackkat
I have an older television that does not have any output or input audio/video ports, only a plug for the outlet and the cable. The outlet plug runs to the cable box and the cable box plugs in the wall. Is there some type of splitter that will allow me to hook up my dvd player? Thank you for any advice!!
Username: Project6
Post Number: 927
go to radio shack and look for an RF converter. Tell them your itutationa nd they should be able to help you out.
Home > Message Board > Accessories > Cables > Archive through July 23, 2004 > Unable to hook DVD player to TV? [ « Previous ] [ Next » ]
