Home > Message Board > Accessories > Cables > Archive through July 23, 2004 > 50 ft. Component Cable, bad idea?
Author Thread: 50 ft. Component Cable, bad idea?
Maxx54
Hi,
I just purchased and BenQ PB6100 projector and will need about 43 feet of component cabling to run from my Cambridge Audio Azur 540D DVD player to attach to the VESA adapter. I am installing this temporarily, so I ordered a 50 ft. length from Gepco (for room to play in future installations). My question is: will this length degrade the signal? Should I have kept it as short as possible?
Thanks!
GW
Component cables are designed for low loss and long runs. You should be fine.
Home > Message Board > Accessories > Cables > Archive through July 23, 2004 > 50 ft. Component Cable, bad idea? [ « Previous ] [ Next » ]
