Thread: The MX-700 |
| Posted on Wednesday, October 15, 2003 - 09:40 pm: |
Hey there everyone. Is it true what I saw someone mention about this remote, that you CAN shut off lights with it too? I have used an x-10 like remote, the ibm directo (which I received from smarthome. T If you know much about that let me know, and also what you all are saying about Harmony. |
Derek |
| Posted on Thursday, October 16, 2003 - 07:47 am: |
Radio Shack sells a few universal remotes that also control x10 modules. I have two and they do work. See thier site for the manual on model number 15-1994 for example. Also, see http://www.remotecentral.com regarding the MX-700. |
Bronze Member Username: Audiophiliac
Boise,
ID
USA baby
Post Number: 20 Registered: Jul-04
| Posted on Wednesday, July 21, 2004 - 01:34 am: |
If it uses IR commands, then you can control it. |
New member Username: Toddious
Orlando,
FL
Post Number: 4 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 02:59 pm: |
yes, home depot sells lutron IR dimmers for like $40. any learning remote can learn these codes, and control the lights. |
