Thread: Need Help Choosing Speaker Cable - Dali Ikon 7's |
New member Username: Falcrum
Post Number: 1 Registered: Sep-09
| Posted on Sunday, September 27, 2009 - 09:26 am: |
Hi Guys - I have some dali ikon 7's, connected to Denon 4308, and cd's with a Denon 3800. My question is: I am having trouble choosing which speaker cables to get. People have told me its a waste, this and that. And others say its worth it. I was looking at the Chord Signatures, but to expensive to hook up all my speakers fronts and back. Then I saw the Dali speaker cables red wave (14 gauge -3mm), but its only 14 gauge? I am defeinatly going to use Dali bannana plugs, due to the fact they are neat looking. But I need hel pin chooosing which speaker cables to get. I know I should get cooper wire, due to the dalis bass shortage I was told thanks for your time and help |
Post Number: 2 Registered: Sep-09
| Posted on Sunday, September 27, 2009 - 09:29 am: |
I forgot to mention, im using HDMI LPCM output for video and audio transfer...Is this correct... And what RCA and/or XLR cable should I get to hook up my MartinLogan Descent i subwoofer to the Denon 4308, Thanks |
