Thread: Subwoofer cable needed 30 feet |
New member Username: Rajmpatel
Pleasanton,
Ca
Post Number: 2 Registered: Jul-09
| Posted on Wednesday, July 22, 2009 - 06:25 pm: |
Really appreciate your input as i am new to the home theater audio world. Equipment i have: Receiver: VSX-74TXVI pioneer elite Fronts: Martin Logan Clarity Center: Martin Logan Fresco Sub: Martin Logan Grotto Rears: Speakercraft Aim8Fives question: 1. what cable should i use for the sub (30 feet away) i keep on hearing that a coax with a f connector will work ? i would hate to spend above $50 but intend to for performance sake. thanks a lot. |
Bronze Member Username: Mheath8663
Post Number: 29 Registered: Apr-08
| Posted on Tuesday, July 28, 2009 - 11:20 am: |
Subwoofer cables are not usually F type connectors. You probably need an RCA connector. Here is an inexpensive 25' cable. http://www.findacable.com/servlet/the-777/25ft-VELOCITY%3F-BASS-MANAGEMENT/Detai l and a 50 ft but higher quality http://www.findacable.com/servlet/the-311/50ft-SONICWAVE%3F-RCA-TYPE/Detail |
New member Username: Mozart
Post Number: 3 Registered: Aug-09
| Posted on Wednesday, August 19, 2009 - 05:30 pm: |
Best SPDIF for 50 to 100 foot, but make sure to readjust phasing in the back of the sub for distance. Ask for a price for 30 Feet. http://shop.mozartcables.com/product.sc?productId=11&categoryId=4 |
New member Username: Hot_martyn
Post Number: 1 Registered: Oct-09
| Posted on Saturday, October 17, 2009 - 04:00 pm: |
id go for 30ft tbh |
