Home > Message Board > Accessories > Acoustic Room Treatments > DIY bass trap
Author Thread: DIY bass trap
Username: Mike19
Tallahassee, Fla
Post Number: 12
Hi everybody.
Just wanted to relay something I tried with good results.
I had moved my best sub (a Sunfire True) out of my home theater system and into my "home office" computer system. Put the Sunfire into a corner, as usual, and it sounded way too boomy. Moved it out from the wall, but no improvement. Took a bunch of old, crumpled T-shirts and stuffed them into the corner. Boom gone!
Mike
Username: Wetfishodeon
Post Number: 8
Interesting to see some pictures I promise I won’t laugh.
I wonder what frequency they are absorbing bussed on SPL db?
Corners are a big problem in the home.
And you only need to run a few test gear around the room SPL db RTA to see what you normally wouldn’t see but may just detect the small difference or the pressure at few frequencies being reduced without the need or with minimal EQ use.
I wouldn’t be surprised if the peaks where high in the 40Hz to 50Hz then smoothing out thou to 60Hz and then rising again slightly into the 70Hz the dropping then rising again into the 80Hz then dropping rapidly, maybe because that’s more or less what I see in the corner and the sub is at least 28” away from the corner located along the front wall.
But clothing hmm well unless I have some that is good enough for Oxfam then no I’m not going to start using my best cloths, unless I have some blankets all crumbled up together and stuffed in the corner?
Username: Jspringer
yea, if it fixed your problem, it fixed your problem. I've always had trouble with corners myself, try to stay away from putting any of my equipment in them.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Acoustic Room Treatments > DIY bass trap [ « Previous ] [ Next » ]
