Home > Message Board > Accessories > Cables > Digital Coaxial to optical ?
Author Thread: Digital Coaxial to optical ?
Username: Rockkk
Quebec
Is it possible a digital coaxial to optical cable, because I just have a coaxial plug onto my dvd and a coaxial onto my amp and I want to have a digital sound. So is this cable possible ? Is it existing ?
Username: Glasswolf
NW, MI
Post Number: 12325
you can get an adapter that converts SPDIF to TOSlink or vice versa. Easily found on google. just search for "optical digital coax adapter" or similar.
they carry the exact same signal and data, just two different transports for it.
Username: Mheath8663
Post Number: 26
I find a lot of this kind of items at tekCABLE.com. Here is a Coax to Optical
http://www.tekcable.com/coaxial-to-optical-digital-audio-converter.aspx
and Optical to Coax
http://www.tekcable.com/optical-to-coaxial-digital-audio-converter.aspx
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Cables > Digital Coaxial to optical ? [ « Previous ] [ Next » ]
