Thread: Coaxial to RCA? How... |
New member Username: Aoliver
Michigan
Post Number: 1 Registered: Oct-08
| Posted on Saturday, October 04, 2008 - 04:59 pm: |
So I've searched the archives and all the links are old. I really just need a simple solution. My problem is that the old threaded coaxial jack on the back of my tv has been destroyed. I still have the RCA ports though. I need someone to tell me how to convert coaxial to RCA. Thanks. |
Bronze Member Username: Mheath8663
Post Number: 14 Registered: Apr-08
| Posted on Monday, October 13, 2008 - 09:01 am: |
Adam, It appears that you want to take a Cable/Satellite TV signal via coax and convert to RCA (audio and video). I don't think a simple cable will do this for you. You'll need a converter box. The best solution may be a cable converter box from your cable provider. If I am wrong on this assumption and you are just looking for an RCA to F-Type adapter like this http://www.findacable.com/catalog/27313.jpg You can find it at http://www.findacable.com/servlet/the-48/RCA-MALE-TO-F-dsh-TYPE/Detail |
Bronze Member Username: Rainnaunseque
Post Number: 29 Registered: Dec-08
| Posted on Friday, May 15, 2009 - 07:11 am: |
no need |
Post Number: 30 Registered: Dec-08
| Posted on Friday, May 15, 2009 - 08:10 am: |
no need |
Gold Member Username: Donnie1973
Post Number: 3185 Registered: May-06
| Posted on Monday, June 01, 2009 - 10:35 pm: |
just a vcr will do |
