Home > Message Board > Accessories > Cables > Supra Rondo 4x2.5 mm² or 4x4 mm²?...
Author Thread: Supra Rondo 4x2.5 mm² or 4x4 mm²?
Username: Turner73
Post Number: 10
Hello.
I have B&W803D front, HTM2 center, Cinenova Grande 7-Channel.
I am looking at new speaker cables (biamp the 803s). I started with the Supra sword, but the problem is that 5 runs of 7m (yes I need 7m) it costs about 3000euro. This is a little too much. I would really appreciate some advice.
- First, should I go for the 2.5mm or the 4mm rondo? They say that it is for large wattage...
- Second, should I go for the Rondo at all or do you have some other alternatives?
- Third, termination. As I see it raw cable (no termination) securely screwed tight in a post is better than a banana or a spade... ?!
Thanks.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Cables > Supra Rondo 4x2.5 mm² or 4x4 mm²?... [ « Previous ] [ Next » ]
