Thread: Belling-Lee (TV aerial plug/PAL connector) to F-Pin anyone? |
New member Username: Lifeinseattle
Seattle,
WA
US
Post Number: 1 Registered: Apr-08
| Posted on Wednesday, April 30, 2008 - 02:03 am: |
I have a European TV with, to my best research, a Belling-Lee or TV Aerial plug/PAL connector cable connection and would like to connect my coaxial cable to this TV. First, am i using the correct terms for these connections? If not any suggestions? Second, is there a converter piece/cable for this TV? If so, suggestions as to where to buy? Much help for any suggestions. |
Relevant Product Info
New member Username: Mheath8663
Post Number: 2 Registered: Apr-08
| Posted on Thursday, May 01, 2008 - 10:48 am: |
You can find an adapter cable at http://www.theautomationshop.com/product_info.php?products_id=285 Hope this helps, Mike http://www.findacable.com |
