Thread: Component cable picture problem |
New member Username: Egonb
Post Number: 1 Registered: Apr-08
| Posted on Thursday, April 24, 2008 - 01:22 am: |
i'm new here and this may be an easy/silly question to solve. but it's driving me absolutely insane! i recently got a prima hdtv. i had been using the red,white,yellow cables to hook up my pioneer dvd player and had no problems. however, i found out using component cables (red,green,blue) gives you a better picture quality. indeed they do. but here's the problem...... when watching a dvd with the component cables (ypbpr setting), whenever a scene in the movie makes the screen go completely white (ie an explosion) my picture cuts out for about 7 seconds and it says no signal. why is this happening??? i've checked all my connections and settings and everything seems right. do i need a new dvd player (mine is about 5 years old) or simply some different cables? any help would be MUCH appreciated as it's driving me insane! |
Relevant Product Info
Platinum Member Username: Project6
Post Number: 15816 Registered: Dec-03
| Posted on Thursday, April 24, 2008 - 09:48 am: |
Did you check the integrity of your cables? |
Post Number: 2 Registered: Apr-08
| Posted on Thursday, April 24, 2008 - 11:05 am: |
by integrity do you mean quality? they're "nexxtech evolution series cables". 90cm (3'). the guy said they were good quality. but can you ever really trust salesmen? lol. are there better quality cables i should be looking for? someone else suggested it could be my dvd player since it's almost 10 years old. |
Post Number: 15818 Registered: Dec-03
| Posted on Thursday, April 24, 2008 - 11:50 pm: |
I meant to say if your cables are not compromised by any means. If they are brand new cables, then the culprit you should be looking at would be the DVD player. |
