Thread: RCA to 1/8 Female |
New member Username: Rusguitar
Floydada,
TX
Post Number: 2 Registered: Apr-08
| Posted on Saturday, April 05, 2008 - 04:56 pm: |
I've got a DVD player as my audio source. My video is going out to a projector, but I need to connect the audio to the speakers we have. The speakers have a 1/8 cable that wants to connect to the source, so I need to go from the 2 male RCAs to a 1/8 Female so that I can plug the speakers' male end into that female. I hope that makes sense... Anyone have a link to the correct cables I need? Thanks! |
Platinum Member Username: Project6
Post Number: 15665 Registered: Dec-03
| Posted on Wednesday, April 09, 2008 - 11:31 pm: |
Does your DVD player have speaker outputs? Are the speakers powered? If not, you will need a receiver before you can connect them to the speakers. But if you think they will work, try going to Radio Shack, they will have the connector you need. |
