Thread: Analog Interconnects? |
Bronze Member Username: Darrenmc
Winnipeg,
Manitoba
Post Number: 76 Registered: Mar-04
| Posted on Saturday, March 15, 2008 - 05:35 pm: |
I've been looking at upgrading my interconnects from my source (Moon CD-1 cd player) to my receiver (Arcam AVR 300) but there are so many options? Right now I'm using Tara Labs Spectrum2A interconnects which are okay, but I'd like o try something new. I don't want to break the bank and like to stay in the $100-$125 range. Here are some interconnects that I'm looking at: Cardas - 300B Microtwin's or Quadlink 5C's (may be outta my range) Alpha-Core/Goertz Micropurl's Straightwire Encore II's (not sure of the price?) Analysis Plus Oval One's Audio Art IC 3's Speltz Anti-Cable's Kimber PBJ's or Timbre's DH Labs BLI's The first group I can buy local and the second group I'd have to order on-line. I'm looking to add a bit more detail to my system so if anyone has comments or suggestions about these cables please do so. Thanks in advance. |
Platinum Member Username: Project6
Post Number: 15449 Registered: Dec-03
| Posted on Saturday, March 15, 2008 - 07:33 pm: |
I use Kimber Kables, with NAD and Outlaw Audio equipment. |
Silver Member Username: Floyd_1977
Montgomery,
IL
Post Number: 121 Registered: May-06
| Posted on Tuesday, March 18, 2008 - 01:32 pm: |
What exactly is different about the interconnects you listed and a well-constructed $10 interconnect (other than price) that would make your system sound more "detailed"? Have you looked into the high resolution audio formats (SACD and DVD-A)? Source material encoded in these formats may provide you with more detail, depending on what type of speakers you have, or course. Interconnects will not. |
Post Number: 15479 Registered: Dec-03
| Posted on Tuesday, March 18, 2008 - 06:56 pm: |
We can talk about that until we are blue in the face, I doubt anybody listens anymore |
New member Username: Hudsy
Windsor,
Ontario
Post Number: 2 Registered: Jan-08
| Posted on Sunday, February 22, 2009 - 10:48 am: |
I know this is an old post so I am not sure if you are still in the market or if you have made your choice. I have an Arcam 300. I had a set of Kimbre PBJs and they weren't bad but not extremely detailed. I picked up a set of second hand Blue Heaven interconnects and they sound really good, more detail/better synergy. I have also tried various Van Den Hul cables and The Well sounded good. I have also heard that the Van Den Hul DS-102MKiii work well with Arcam gear as well as Chord. I am on the lookout for a set of Chord Chameleon Silver Plus 2 as I have heard they work great with Arcam gear. I do have a set of DH Labs Air Matrix on their way to me. I for one do hear a difference with different cables connected, better synergy. |
