Thread: Cable for Rega set up |
New member Username: Shari
Knebworth,
Hertfordshire
UK
Post Number: 1 Registered: Feb-08
| Posted on Monday, February 04, 2008 - 11:31 am: |
Hi Guys This is my first post so I hope you will be gentle!! I have the following set up Rega Apollo CD Cursa3 Maia3 JM Lab Focal Chorus 816V Chord Rumour speaker wire Chord Chameleon Silver Plus interconnects I am getting to what I believe is the end of the burning phase and am finding this set up overally smooth. The detail is there plus the bass and high frequecies, but the excitement is missing and the vocals are not what I call solid!??. Yesterday I changed the speaker cable to Naim NACA5 and the difference was amazing. The excitement and involvement was there and the vocals where a touch more forward and solid and not vague as before. I am finding the music a tad bright though (or is it inceased detail???) and some of the warm rounded sound has gone. Is this a trade off for excitement in the music or can I bring the warmness back with the excitement? I know at least a few of you have good experience with Rega, namely Frank and Art, and would welcome you comments or suggestions. I must say the Focals on the end of the Rega doi sound good, so this is more about subtle cable changes rather than equipment change and I am trying to get the last 5-10% out of my current set up. Cheers in advance Shari |
Relevant Product Info
Knebworth,
Hertfordshire
UK
Post Number: 2 Registered: Feb-08
| Posted on Monday, February 04, 2008 - 03:22 pm: |
OK guys. I have changed the cable back. What I thought was more excitement was an illusion, they both sound practically the same. I would like to open up the sound a bit more though as it seems a bit closed in the mid band. Suggestions? Cheers |
Platinum Member Username: Project6
Post Number: 14677 Registered: Dec-03
| Posted on Monday, February 04, 2008 - 09:21 pm: |
Nice set up Shari If you want Frank and Art's input, you may want to post this in the Home Audio section. I know it may not be in the right area but they do not frequent this part nowadays. |
