Thread: Y - Connector for Subwoofers???? Please Help.... |
JJ |
| Posted on Sunday, July 27, 2003 - 02:50 am: |
I have a JBL PB-10 with connections to my Receiver (Sub Out). The sub has both L and R input. Would it be better to use a Y - connector and use both signals or just use 1 channel? If so or if not, why? Please explain in detail. Many Many Thanks, |
| Posted on Thursday, September 11, 2003 - 06:41 am: |
i read somewhere that there is a 10 dB increase if a y cable is used to connect both L and R of the sub. That means more bass for the same signal. |
Ben |
| Posted on Thursday, October 16, 2003 - 09:27 pm: |
Yes, it would be better to use a Y-connector for your sub. That's what I did for my Velodyne HGS-12. Definitely an increase in bass and since mine uses the signal from the subwoofer cable to auto on itself, the Y-connector helped the subwoofer to auto on itself at a lower set volume from my pre-amp. Jansen is correct in his statement about an increase of 10 dBs. I have read articles stating the same with a range of 3-10 dB increase in bass. You can't go wrong adding a Y-connector to your sub. |
| Posted on Wednesday, January 07, 2004 - 12:03 am: |
If it is a JBL, then one of the inputs (left, I believe), should be LFE (low frequency signals only) that comes directly from your receiver. Just connect the sub out to the LFE jack. I know that the JBL PB-12 works that way. |
New member Username: Sbull
Post Number: 6 Registered: 02-2004
| Posted on Tuesday, February 10, 2004 - 10:28 pm: |
If anyone needs a quality Y connector, just ran across this at Parts Express: http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=18419390&St=9806&St2=-80707 133&St3=70683438&DS_ID=3&Product_ID=117481&DID=7 Thanks, Hawk. I was looking for a place to order decent cabling at a reasonable price. |
New member Username: Trekz_inc®
Post Number: 3 Registered: Jun-04
| Posted on Wednesday, June 16, 2004 - 11:42 pm: |
I myself have a Y connector from the receiver to a 500 watt peavey amp. I have a pair of subs on each side of the front speakers....works great!! Sounds great as well. |
