Thread: DVD Player -> Projector |
New member Username: Mrwoody
Post Number: 1 Registered: Oct-07
| Posted on Saturday, October 27, 2007 - 02:03 pm: |
Hi! I have a very simple question. My dvd player has a hdmi+component+composite output and my projector has a vga+s-video+composite input. Is there a better way to connect them, rather than using composite? |
Relevant Product Info
New member Username: Johnb231
| Posted on Sunday, October 28, 2007 - 02:31 am: |
Hi, I have a question about connecting the cables to a HD DVR unit, do the satellite cables connect to this box the same as they did to the reg DVR box, and the HDMI cables was I correct when I read that you still have to ren a audio cable (the red&white cables) to receive audio because the HDMI does not transmit sound? Thanks in advance------------------John |
Post Number: 2 Registered: Oct-07
| Posted on Sunday, October 28, 2007 - 02:35 am: |
can any one tell me if I have to activate the HD cards to use the HD DVR box, I am replacing the reg DVR box with the HD DVE box, I was wondering of I could use the reg card until the 5 eyed dish was installed, or do I have to activate the HD card immediately? Thanks-----------John |
Bronze Member Username: Floyd_1977
Plainfield,
IL
Post Number: 92 Registered: May-06
| Posted on Tuesday, November 06, 2007 - 11:33 am: |
Mister Woody, Component is much better than composite. John Harris, HDMI transmits both audio and video. I don't know about your activation question. You'd be better off contacting your satellite provider or posting your question in the appropriate forum. |
| Posted on Tuesday, November 06, 2007 - 09:07 pm: |
I guess you mean that I need something like Composite-> VGA, right? |
Plainfield,
IL
Post Number: 93 Registered: May-06
| Posted on Wednesday, November 07, 2007 - 07:48 am: |
Oops, sorry. I read your post too fast and thought your projector had a component input. I guess if that were the case, you wouldn't be asking this question. I would suggest looking into buying a home theater projector, as opposed to using an office/PC projector, which is not intended for watching movies. |
Post Number: 3 Registered: Oct-07
| Posted on Wednesday, November 07, 2007 - 08:33 am: |
Thanks for your reply. I own a Benq 6200 and I don't think it is a PC projector. I would give a try to a composite->VGA cable. |
