Thread: Component wires? |
New member Username: Kober
Post Number: 3 Registered: May-04
| Posted on Wednesday, May 19, 2004 - 05:45 pm: |
I got Acoustic Research Component wire for my dvd player. Im wondering if I should get some nicer ones,They were only 25$. Anyone got some suggestions? |
| Posted on Thursday, May 20, 2004 - 10:48 am: |
AR is fine. I don't believe you'll notice any difference with a more expensive one and I don't think anyone on these boards will tell you differently. |
Post Number: 5 Registered: May-04
| Posted on Saturday, May 22, 2004 - 07:29 pm: |
Ok thanks, but on some DVD's I get this weird stuff in the picture,like If the sharpness is turned up, you get that weird looking stuff..It looks like that with the sharpness even turned down, it happens on alot of DVD's, so I turned the Digital Video Enhancer on my DVD player to soft,that helps alot. |
