Home > Message Board > Accessories > Cables > Trying to connect PC to Amplifier Aud...
Author Thread: Trying to connect PC to Amplifier Audio and Projector VGA
Username: Tomo22
Nakhon Ratchasima
Thailand
I am trying to connect my PC to my Projector.
The PC video card has 2 dvi i connectors for dual display or a HDTV out connector. Using the HDTV connector I can get 1080i. Fine However I would like to output in Computer Resolotion 1024 x 760.
I have a 15 meter HDTV cable RGB and purchased two VGA to RGB converter cables. My projector has VGA imput with this arangment I can still only get HDTV outputs is there a work around or do I need to purchase a long VGA cable.
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Accessories > Cables > Trying to connect PC to Amplifier Aud... [ « Previous ] [ Next » ]
