Home > Message Board > Accessories > Power Conditioners > Power cords
Author Thread: Power cords
simon clarke
do thay make a difference?? yes, & how much do thay cost? i have new tci constrictor which takes 150 hours to burn in, the cable i have is 89.99 & the min you want to pay it runs the new arcam cd 72 it adds so much you, can never go back.
I think this is something like a miracle purchase. It's the little things in life.
Username: Eramsey
South carolina
United States
Post Number: 11
NO. They do not make a difference. Cables or powercords do not need a "burn-in" period. This is a scam. Avoid it and save your money for things that matter such as equipment or speakers. E. Ramsey AAS industrial electronics
Username: Uback007
Post Number: 144
Eric..are you saying that all power cables do not make a difference or that the burn-in is a scam?
Username: Eramsey
South carolina
United States
Post Number: 516
This thread is ancient Uback where have ya been???! I think that lowering the impedence(very marginally) in an AC circuit certainly won't be harmful and could be beneficial but I don't think it will make an audible difference in nearly all but the highest end systems out there,and even then the difference will be very subtle at best, As far as burn in goes let's not get started, these arguments grow weary these days,believe what you want, I do suggest however, that you a little research yourself and you will find that science is able to prove that burn-in as well as many other "mysticisms" about cables are unfounded. Buy well shielded cables to prevent interference, that's what you need to be concerned with in a cable.
Username: Uback007
Post Number: 147
okay. can you recommend a good bang for the buck power cable to upgrade to?
Yes, I just saw that there was a "power conditioning" section in the forum and because I am in the market for cables, it's the first place I came.
Please help! :-)
Username: Leonski
Post Number: 96
Real, honest to goodness DOUBLE BLIND testing is the way to evaluate this stuff.
No amount of science will ever convince most of the people who think they have THE golden ear, that at least for speaker and power cables of good fundamental design and execution, there are nearly NO measureable differences that you can hear.
I repeat:: DOUBLE BLIND TESTING ::
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Power Conditioners > Power cords [ « Previous ] [ Next » ]
