Thread: Room echo |
Bronze Member Username: Develara
Post Number: 27 Registered: Dec-06
| Posted on Thursday, July 05, 2007 - 09:51 am: |
hi all , I am trying to set up a new home theatre in a all new built room , the size is 11 *19 and the ceiling is around 13 feet high , the problem is the echo , if i have a false roofing will the echo be arrested or is it necessary that i should go for these bass traps , absorbers etc etc ... since my budget is minimum i want to choose either one dev. |
Post Number: 29 Registered: Dec-06
| Posted on Saturday, July 07, 2007 - 07:30 am: |
any one? |
Gold Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 8349 Registered: Jun-06
| Posted on Saturday, July 07, 2007 - 09:47 pm: |
"if i have a false roofing" Do you mean a dropped acoustical ceiling? Also, is this room carpeted or hardwood/laminate flooring? Big difference with the flooring. |
Silver Member Username: Leonski
Post Number: 133 Registered: Jan-07
| Posted on Thursday, July 12, 2007 - 02:54 am: |
Really entertaining youtube entry in the DIY BassTrap catagory. www.youtube.com/watch?v=iyYUpkpL0gw |
Post Number: 31 Registered: Dec-06
| Posted on Tuesday, August 21, 2007 - 03:15 am: |
paul , the room is carpeted and has a dropped acoustical ceiling , but still i find echos and over booming of bass. any thing i can do to improve the room acoustic? dev. |
Post Number: 32 Registered: Dec-06
| Posted on Tuesday, August 21, 2007 - 03:30 am: |
thanks leo , the youtube site was very informative., I'll have a try. dev. |
Post Number: 173 Registered: Jan-07
| Posted on Wednesday, August 22, 2007 - 08:35 pm: |
I tamed a room echo with the simple addition of a heavy wool tapestry hung on the wall opposite the speakers. the room is about 25' long and the echo from the far wall was Very distracting. For booming bass, you can try to elevate the speakers, move them away from corners, or move them away from the back wall, any of which will help. google: bass trap, and look up DIY stuff using DC703. simple, effective and not too much $. Other room treatments to consider include carpeting and 'soft' furniture..... |
