Home > Message Board > Accessories > Remote Controls > The remote to my Orion TV Broke..
Author Thread: The remote to my Orion TV Broke..
Username: Connie_decole
i have an Orion Tv my remote broke and now i can't access my DVD channel (aux) what do i do can anyone help?
it's Model Number.1333
Made/March 2001
Thanks
Relevant Product Info
Username: Red99wardog
Try Pressing both volume buttons at the same time. You should be able to get into the set up screen.
On my Orion TV, I was able to access or change to the Aux, for the dvd, by pressing the channel up button and holding it there, or by pressing up twice, in quick succession.
The only way I could get out of the aux channel was to unplug the TV. I have not yet been able to program my Universal remote for the model 1333. Still working on that.
good luck,
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Accessories > Remote Controls > The remote to my Orion TV Broke.. [ « Previous ] [ Next » ]
