Home > Message Board > Accessories > Antennas > Need Advice on UHF TV Signal Amplifier
Author Thread: Need Advice on UHF TV Signal Amplifier
Username: Eamonx1
Cork, Munster
Ireland
Remote UHF signal needs to be amplified. (in Ireland). I have the correct antenna and can source the signal - but it is very weak and hazy. Know v. little about amplifiers. Can you suggest appropriate model I might purchase to boost signal? Or give me advice
Username: L20109
Try an indoor booster. In most cases, it will give rezonable or good pictures.
I'm a student at CPUT in South Africa and I'm planning to build an AM to FM converter circuit for my final project. Little information is provided on the website where I found the ciruit (electronics-lab.com/project). Maybe you can help me with more details of how the circuit works and what kind of capacitors can be used.What frequency is it operated on,FM/AM?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Antennas > Need Advice on UHF TV Signal Amplifier [ « Previous ] [ Next » ]
