Thread: HELP. Teac UR-410 remote control needed |
New member Username: Geetee
Custer,
SD
Post Number: 1 Registered: Feb-07
| Posted on Monday, February 26, 2007 - 06:12 pm: |
I have a TEAC UR-410 remote control for my AG-V8520 receiver. A few of the remote's buttons no longer function and I'm seeking a replacement for it. Can anyone help? Please email me if you can, put TEAC REMOTE in the subject if you would. Thank you in advance.} |
Relevant Product Info
Gold Member Username: Samijubal
Post Number: 3320 Registered: Jul-04
| Posted on Wednesday, February 28, 2007 - 10:00 pm: |
Open the remote and lightly clean the buttons and circuit board with a q-tip wet with alcohol. Don't get too agressive with the cleaning or you'll rub off the carbon coating. |
Custer,
SD
Post Number: 2 Registered: Feb-07
| Posted on Monday, March 05, 2007 - 11:55 am: |
Thank you David. I took your advice and cleaned the contacts as you suggested and it now works as good as new. I really appreciate your tip on doing that. I have a couple of other older remotes that are doing the same thing and now I have confidence, that using your tip, I can get them back to working in good order again. It's always good, when something nice like this happens on the internet. |
