Home > Message Board > Accessories > Acoustic Room Treatments > Room brightness
Author Thread: Room brightness
Username: Kinggimp82
Post Number: 46
im experiencing brightness and would like some tips to treat my room.
i live in an apartment. room is aprox 15' wide x12' deep x 8' high. the right side opens to the kitchen. the left side is a large plate glass window with blinds. the floor is basically indoor outdoor. its like basement carpet over concrete. and the back wall is pretty much empty drywall.
incase you need to know my system is as follows.
FRONT: ascend accoustics CBM-170 SE'S
CENTER: ascend accoustics CMT-340 C SE
SURROUND: None (ascend accoustics HTM-200s soon)
SUB: Hsu STF-2
REC: Pioneer VSX-514
what could i do to treat my room? id imagine a large rug and thick curtains would help. any info would be much appreciated.
thanks,
andrew
Username: Eib_nation
Ohio
EIBville
Post Number: 153
Try googling 'acoustic room treatments'.
This is exactly the type of treatment you need to fix the acoustics of any room.
www.gikacoustics.com
Many companies offer these types of products, and you should research many to see which fit's your needs the best.
Good luck.
Username: 865warren
Post Number: 9
As mentioned many companies offer this service so I would compare what they are offering and prices - there are sometimes huge differences...
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Acoustic Room Treatments > Room brightness [ « Previous ] [ Next » ]
