Thread: Antenna Setup |
Bronze Member Username: Arande2
Post Number: 80 Registered: Dec-06
| Posted on Wednesday, December 13, 2006 - 06:30 pm: |
Thanks in advance......................................................................... ......................... I have this outdoor FM antenna on a rotator that's sitting in the attic already set up. I want to hook it up to both my receivers that take either 75 or 300 ohm inputs. I was just wondering how to go about hooking it up to BOTH. I guess what I should be asking is...How do I split the output of an FM antenna for hookup to two stereos for best results (an amplifier, certain cable, etc)? ................................................................................ ....................for responding |
Silver Member Username: Boyce
Post Number: 316 Registered: Apr-06
| Posted on Saturday, December 30, 2006 - 12:29 am: |
just use a 75 ohm 2 way splitter and use 75 to 300 ohm converter to 300 ohm reciver. |
Silver Member Username: Arande2
400dB could probably d...,
4000 isnt ev...
100,000dB FU...
Post Number: 517 Registered: Dec-06
| Posted on Saturday, December 30, 2006 - 12:35 am: |
Are you sure? The problem is the antenna is pretty far away(200 ft). I guess I can try hooking it up and see if the signal is strong enough. |
Post Number: 317 Registered: Apr-06
| Posted on Sunday, December 31, 2006 - 06:15 am: |
I don't know the size of your antenna, I can't tell how much it gain, but a 2way splitter will lost 3.5db. |
4000 isnt ev...
100,000dB FU...
Post Number: 617 Registered: Dec-06
| Posted on Sunday, January 07, 2007 - 06:23 pm: |
Well, the Antenna says +12dB, so I think it'll be strong enough of a signal. |
