Thread: Good Subwoofer Cable..? |
New member Username: Arande2
Post Number: 10 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 11:08 pm: |
I will be getting a MartinLogan Descent and hope to connect it using an XLR cable, but I need to know where to get a good high quality XLR, or what company to get a good XLR cable. I've heard a lot of good things about StraightWire cables. www.straightwire.com |
Platinum Member Username: Project6
Post Number: 11752 Registered: Dec-03
| Posted on Tuesday, December 05, 2006 - 11:18 pm: |
Straightwire makes good cables. There's also Kimber Kables and Blue Jeans. They are all good, different prices. |
Bronze Member Username: Arande2
Post Number: 13 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 11:27 pm: |
Interesting, ha you didn't post that long ago. Thanks I'll definitely take a look at those, and I only knew about straightwire since our local high-end dealer only uses straightwire. |
Post Number: 15 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 11:33 pm: |
Could you give me the URLs? (don't wanna google) |
Post Number: 11756 Registered: Dec-03
| Posted on Tuesday, December 05, 2006 - 11:47 pm: |
http://www.bluejeanscable.com/store/balancedaudio/index.htm http://www.kimber.com/Products/Connectors/Analog/Analog.aspx |
Post Number: 18 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 11:51 pm: |
Looks like I'm just going to have to listen to them for myself. |
Post Number: 47 Registered: Dec-06
| Posted on Monday, December 11, 2006 - 12:15 am: |
How much difference does a good cable make anyway!?} |
Post Number: 11840 Registered: Dec-03
| Posted on Monday, December 11, 2006 - 12:26 am: |
Different schools of thought on that one. You have to decide for yourself. But do not get into any sort of debate over them...it is a conundrum of sorts. |
Post Number: 49 Registered: Dec-06
| Posted on Monday, December 11, 2006 - 12:32 am: |
The whole point of cables is signal transer I'd suspect so losing the least amount of signal possible would be the goal I presume. StraightWire has caught my eye and so I'm guessing I'm going to get more of those for all my equipment. |
