Thread: Need to extend my speaker wires (not sure what to buy) |
Bronze Member Username: Spawn_2_extreme
Ontario
Post Number: 16 Registered: Jun-06
| Posted on Wednesday, November 29, 2006 - 10:10 pm: |
I have a 5.1 set of speakers, The two rear speakers need to be extended, I just need them about 30ft, two of them. The wire has one red and one black wire, at the back of the speaker theres like a red switch I have to press down and put the red wire in and same for the black, It's the same for my receiver, I am looking for a wire like that atleast 30ft, I'm not sure if there are different types but list the best brand of those types of cables. I'll be putting those wires inside the wall. |
Platinum Member Username: Project6
Post Number: 11655 Registered: Dec-03
| Posted on Wednesday, November 29, 2006 - 10:23 pm: |
Go here for speaker cables https://secure.libertycable.com/ecomm/catalog/cat_search.php or http://www.partsexpress.com/webpage.cfm?WebPage_ID=3 |
Ontario
Post Number: 17 Registered: Jun-06
| Posted on Thursday, November 30, 2006 - 02:13 am: |
I need to know what type of cable it is, I don't know the type meaning RCA,Coax, etc. Once I know the type I might be able to get better results. |
Post Number: 11672 Registered: Dec-03
| Posted on Thursday, November 30, 2006 - 10:11 pm: |
Dude you can just strip the speaker wires and connect it to the speaker mounts. You don't need any special type of speaker wire. |
Ontario
Post Number: 18 Registered: Jun-06
| Posted on Friday, December 01, 2006 - 07:15 pm: |
thanx for the info |
New member Username: Petrus
Spain
Post Number: 1 Registered: Dec-06
| Posted on Wednesday, December 13, 2006 - 04:42 pm: |
I want to buy a BOSE acoustimass 10 home cinema speakers but I was told they use "special" cables to the speakers so I can not use my normal (copper) cables. What can happen when I use this copper cable instead of the Bose? |
Post Number: 11917 Registered: Dec-03
| Posted on Wednesday, December 13, 2006 - 06:49 pm: |
You don't need special cables. |
