Thread: TV remote problem... |
New member Username: Adela
New York,
NY
Post Number: 7 Registered: Apr-05
| Posted on Wednesday, November 22, 2006 - 07:27 am: |
Hello, I searched for "TV Remote Problem" but didn't bring any results... I wonder if anyone came across a similar experience? I bought a Panasonic TV with an RCA RCR450 Universal Remote from a neighbor who moved out. The TV works perfectly. The remote worked fine for a few months, but now it just stopped functioning, and the only thing that works is the indicator light on pressing any key...but the remote is still not responding. I went to RCA website and copied down the TV codes...but I don't know how to insert those codes. I pointed at the TV, I tried to follow their instructions, I pressed the TV button, entered those codes one by one...but nothing happened! Would anyone know what is the procedure for those blessed codes? I'd like to try it before I have to buy another one which I'm not sure if it's worth it... Thanks so much for any help. Adela P.S. In case I'm not describing this well, here's the RCA website link: http://support.rca.com/doc/rca1833.xml?docid=983&Referring%20DocID%20List%20Inde x=1&navtypeid=6&pagetypeid=2&prevPageIndex=5&selectedmodel=RCR450&selectedFamily =generic And this is what I don't understand: [QUOTE]Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the Code Search methods instead.[/QUOTE] Thanks again!  |
New member Username: Cx3200
Post Number: 2 Registered: Mar-07
| Posted on Tuesday, June 05, 2007 - 10:23 pm: |
Panasonic TV :Using a universal remote / have you tried the remote on any other device to check that it works , it could be the transmitter : Clean the lens and use good batteries to test: you can get a original tv remote for your model of tv of the net: £12/£15approx: |
New member Username: Tish
Post Number: 8 Registered: May-06
| Posted on Monday, September 24, 2007 - 10:56 pm: |
Having a problem with my remote for pansat 2700a receiver. Indicator light comes on when you press the buttons but nothing happens. I have tried putting new batteries and I still get nothing. Can anyone tell me how to fix theis, or do I have to buy a new one. Thanks |
New member Username: Rfmd70
Post Number: 2 Registered: Nov-07
| Posted on Thursday, November 22, 2007 - 10:55 pm: |
I am also having a remote problem. I have a magnavox tv and 3 different remotes that once worked with it. Now none of the remotes are working they have new batteries, I cleaned the remote sensor on the tv, and have tried reentering the codes in the remotes. Any suggestions? |
