Thread: Composite as Component? |
New member Username: Dark_wolf
Post Number: 1 Registered: Nov-06
| Posted on Monday, November 13, 2006 - 10:07 pm: |
Hi, I've bought a projector for my home theater that can display up to 480p. The guy at the shop sold me a 150$ cable that really look like a composite one. (It has the colors red-white-yellow) But the fact is that I need a component cable for my projector. Can this cable be used as a component cable? In fact, can we use a composite cable as a component cable? Are they made the same way? |
Silver Member Username: Leew
illegal immigrantoŽ ,
Yokosuka, ...
SPESNAZ ZOMB...
Post Number: 715 Registered: Jan-06
| Posted on Tuesday, November 14, 2006 - 03:41 pm: |
you can try, |
Post Number: 3 Registered: Nov-06
| Posted on Tuesday, November 14, 2006 - 10:10 pm: |
I made the test : It works! But the image seemed to be darker... Is it because the cable I used from my DVD to my receiver is a cheap (composite) one? |
Gold Member Username: Samijubal
Post Number: 3115 Registered: Jul-04
| Posted on Wednesday, November 15, 2006 - 02:51 am: |
Everything you could ever want to know about component cables. http://www.audioholics.com/techtips/audioprinciples/interconnects/ComponentVideo Cables.php |
