Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > Can Video 75Ohms cable be used for Au...
Author Thread: Can Video 75Ohms cable be used for Audio.
Username: Pramodapple
Sharjah, UAE
United Arab ...
Post Number: 10
Dear All,
I have got some of "Belden 9259 RG59/U 75Ohm cable" I knew that 75 Ohm cables are generally used for Video, but from the Google I found that these cables can also be used for audio as well, I'm planning to make RCA cables out of these "9259 belden" as I have enough cable (I also have some good quality RCA connectors) and use it between my processor and power amp. can some one throw some light on this, weather I can or I cannot.
one or all opinions are welcome and are highly appreciated.
Thanks in Advance.
Username: Samijubal
Post Number: 3078
Yes, you can use coax for audio. I've got RG6 run about 40' to a back room, it works fine.
Sharjah, UAE
United Arab ...
Post Number: 12
Greetings David Massey,
Thats great to hear, I will make 5 cables and use ti between my processor/poweramp. thx for your reply.
are there any more using the cable for the same purppose...???
awaiting for some more input.
Username: Gamerdude
Ontario
Post Number: 253
Sub cables and coxal 5.1 cable or whatever its called
I use my monster component cable for audio sounds good to me
Username: Djnetjero
i have an amp with 1,200 watts mono and how do i connect 3 woofers 400 watts.
Sharjah, UAE
United Arab ...
Post Number: 15
Dear Kyle Robinson,
I have Mafco Component and Monster component cables laying around, so can I use these component cables with my audio gear, I have NAD C162/272 with B&W 602S3 speakers.
Thx in advance for you time.
Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > Can Video 75Ohms cable be used for Au... [ « Previous ] [ Next » ]
