Thread: SPDIF to Standard RCA |
New member Username: Jazzcow
Post Number: 1 Registered: Oct-06
| Posted on Monday, October 16, 2006 - 01:19 pm: |
So the only audio out my TV has is a SPDIF, yet the old receiver I have doesn't have any SPDIF ports, only standard red and white RCA ports, is there any converter/adapter I can use to connect these? Thanks for the help I really have no idea. |
Platinum Member Username: Project6
Post Number: 11347 Registered: Dec-03
| Posted on Tuesday, October 17, 2006 - 06:05 pm: |
Unfortunately the converter is called a receiver. What you are basically trying to do is change the digital signal to analog so you can connect it to the "old receiver". What kind of receiver is it? |
Post Number: 2 Registered: Oct-06
| Posted on Tuesday, October 17, 2006 - 08:25 pm: |
It is a Sony STR-D790, I do not know if that helps. |
Post Number: 11350 Registered: Dec-03
| Posted on Tuesday, October 17, 2006 - 08:58 pm: |
I was just curious. |
