Home > Message Board > Accessories > Remote Controls > Can 1 remote work for 4 separate DVD ...
Author Thread: Can 1 remote work for 4 separate DVD players at once?
Username: Davidson_h
Richmond
I know, probably a weird question. I'll break down what I'm doing first. It's a project involving four TVs with a DVD player going to each one, all running simultaneously. Now, if the DVD players are the exact same brand and model, can I use one of the remotes that came with the players to control all four? (Basically, all I need to do is start the DVDs at the exact time.)
Any help in this would be greatly appreciated. Thanks.
Relevant Product Info
Username: Samijubal
Post Number: 3068
Yes, as long as all the players are within range of the remote.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Accessories > Remote Controls > Can 1 remote work for 4 separate DVD ... [ « Previous ] [ Next » ]
