Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > Digital Coax vs TOSLink: A difference...
Author Thread: Digital Coax vs TOSLink: A difference that matters?
Username: Graylin
If one is using a good quality cable over a short run (2 M) is there reason to install one cable over the other? If the option exists should one install both?
Username: Project6
Post Number: 10704
Not necessarily, it is a matter of perceived difference. Different camps have different opinions whether or not there is a difference or that one is better than the other.
Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > Digital Coax vs TOSLink: A difference... [ « Previous ] [ Next » ]
