Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > Shorter the cable the better signal?
Author Thread: Shorter the cable the better signal?
Username: Gamerdude
Ontario
Post Number: 150
So i was wondering the shorter the audio/video cable the better signal?? or dose it not matter what length the cable is?
Username: Samijubal
Post Number: 3029
There are way to many variables to just say yes or no. What type of cable are we talking about and how long?
Username: Gamerdude
Ontario
Post Number: 152
its really nothing that i would care to "mod" or "diy" to my cables i was just wondering about like a subwoofer cable or component if they were shorter would there be better sound and picture
Username: Samijubal
Post Number: 3034
Can't just say yes or no. It depends on the quality of the cable, length, and the equipment being used. If you just want to know if shorter is better, yes. That doesn't mean you can't go longer without any visable or audible loss.
Username: Gamerdude
Ontario
Post Number: 156
it wasnt more about video more about audio like a 25 foot sub cable compared to say a 5 foot the single would be better stronger bass
am in right about this?
Username: Project6
Post Number: 10589
Not enough for you to actually detect a difference.
Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > Shorter the cable the better signal? [ « Previous ] [ Next » ]
