Thread: Monster cable was it worth it? |
Silver Member Username: Gamerdude
Ontario
Post Number: 116 Registered: Apr-06
| Posted on Thursday, August 17, 2006 - 08:37 pm: |
OK so today well being my lazy self browsing the web i found this.. http://xscargo.com/product.php?dept=Electronics%20Accessor&cat=Audio%20/%20Video &index=36%26item%3D2782763 i thought to myself PERFECT becuz i needed a component cable for my dvd player so i gould get the best possible picture out of it with my lcd and, some extra speaker wire would be in use by chrismas (hopfuly) i want a new amp, so i;m asking do you think it was worth my $35 or so, i havent set it up yet it weights about 5 pounds seemed like a deal to me.. |
Post Number: 9639 Registered: Dec-03
| Posted on Thursday, August 17, 2006 - 09:15 pm: |
The link is not showing the item. |
Ontario
Post Number: 120 Registered: Apr-06
| Posted on Thursday, August 17, 2006 - 11:28 pm: |
http://xscargo.com/product.php?dept=Electronics%20Accessor&cat=Audio%20/%20Video &index=36%26item%3D2782763 hopfuly this one works =) it dosnt sound bad really i dont no if it helped..it sounds cleaner but the speaker cables have some metal probes i just stuck it in and clamped it am i doing somtihng wrong at the end of the cable it have about a inch long probe.. |
Ontario
Post Number: 121 Registered: Apr-06
| Posted on Thursday, August 17, 2006 - 11:30 pm: |
http://monstercable.com/productPage.asp?pin=1597 hopfuly this one works =) it dosnt sound bad really i dont no if it helped..it sounds cleaner but the speaker cables have some metal probes i just stuck it in and clamped it am i doing somtihng wrong at the end of the cable it have about a inch long probe.. |
Post Number: 9647 Registered: Dec-03
| Posted on Friday, August 18, 2006 - 12:09 am: |
That's not a bad price. The pins are just a matter of convenience for connecting to the terminals. But the best connection is still bare wire direct to the terminals. |
Ontario
Post Number: 122 Registered: Apr-06
| Posted on Friday, August 18, 2006 - 11:14 am: |
i was thinking about cutting them off there really seem lik an in convenience for ym speaker selecter that has the "screw type connectors" i gotta put it thorw the hole adn then tighten the screw so i watched transportor 2 last night and sounded and looked great seems like a bargin to me |
Post Number: 9744 Registered: Dec-03
| Posted on Friday, August 18, 2006 - 06:17 pm: |
You can cut them off if you prefer. It is not going to affect anything. |
Ontario
Post Number: 125 Registered: Apr-06
| Posted on Friday, August 18, 2006 - 11:29 pm: |
its 14 ga wire,i may just keep them on dosnt seem to bug me to much yet So what so wrong with monster? i have a cable sliter adn work great adn now i have all that i dont no i think it pretty desent stuff |
Post Number: 9850 Registered: Dec-03
| Posted on Friday, August 18, 2006 - 11:38 pm: |
They work well, they are just overpriced so don't ever pay retail for them. I can get them for less than 50% off but I prefer blue jeans cable. |
Ontario
Post Number: 126 Registered: Apr-06
| Posted on Saturday, August 19, 2006 - 02:46 am: |
At the Xs cargo place they got tons of of s-video,optical whole bunch of cable for under 10$ great deal i;m thinking about stoking up =) Thanks for the help and what not |
Ontario
Post Number: 127 Registered: Apr-06
| Posted on Saturday, August 19, 2006 - 02:47 am: |
All monster seems kool to me |
