Thread: WD-52628 remote control problem |
New member Username: Ariansquare
Post Number: 1 Registered: Aug-06
| Posted on Friday, August 04, 2006 - 11:20 pm: |
I have a Mitsubishi WD-52628 that I bought in Feb 06. My remote control has suddenly stopped working today. When I turn the TV on manually, the screen shows the Volume bar on (63). I cannot control anything on the TV with the remote. I have tried resetting the remote by pressing Power and 935 but that hasn't worked. The remote works with a DVD player that I had programmed it for. Tried a new set of batteries too. Any ideas? |
Gold Member Username: Samijubal
Post Number: 2936 Registered: Jul-04
| Posted on Sunday, August 06, 2006 - 11:26 pm: |
Is there a switch on the remote for TV/DVD. If not it sounds like it's the TV, not the remote. There's a couple of ways to determine if it's the TV. If you have a camcorder you can look at the remote through it while pressing a button in TV mode, you will be able to see if the LED is emitting anything. You could take the remote to an electronics store and see if it operates one of their TVs. |
New member Username: Jaynerkel
| Posted on Monday, August 07, 2006 - 01:03 am: |
Hey everyone. I lost the codes to program my universal remote. I have a Jensen Jer323, if anyone can help that would be great. |
