Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > Convert TOSLink to 3.5mm for 4.1?
Author Thread: Convert TOSLink to 3.5mm for 4.1?
Username: Rage007
Hi, I have a very odd question which may be impossible.
I have a TV/DVD player with a TOSLink digital audio out. I have a set of Klipsh ProMedia 4.1 PC Spearkers that have two 3.5mm front/rear inputs. Is there some kind of converter/cable/unit that will allow me to use my Klipsch speakers with my TV/DVD player?
Thank you!
Username: Project6
Post Number: 9207
Yes, it is called a receiver. :-)
If your TV/DVD player has 5.1 analog outputs, then you can use those. Unfortunately, the ProMedia only accepts analog inputs and is designed for the PC in mind and not TV or DVD player.
What model TV/DVD player is it?
Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > Convert TOSLink to 3.5mm for 4.1? [ « Previous ] [ Next » ]
