Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > 20 feet power cable
Author Thread: 20 feet power cable
Username: Tomcat
Allentown, PA
Post Number: 54
where would I find a 20-foot power cable for my panasonic plasma tv. Any recommendation would be much appreciated.
Username: Samijubal
Post Number: 2886
You can buy a 20' extention cord at any hardware store. A 10 amp extention cord would be overkill for any TV.
Username: Tomcat
Allentown, PA
Post Number: 55
I need to run it inside a chanel and using the extension plug will be difficult to fit.
Username: Samijubal
Post Number: 2889
You can always cut the plug off and install a new one after the cable is run through. You can buy do it yourself plugs at any hardware store too. Or you can buy a length of power cable for installation in houses and put the do it yourself plugs on that. The extention cord would have braided wire which is easer to work with. The cable would be solid wire.
Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > 20 feet power cable [ « Previous ] [ Next » ]
