Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > 5.1 to digital optical adapter
Author Thread: 5.1 to digital optical adapter
Username: Jynxsk8
i need it for my ps2 and dvd player is there any adapter that will let u take my logitech X-530 surround sound system and change the format to digital
Username: Project6
Post Number: 8499
Yes it is called a receiver.
Username: Jynxsk8
where do i get one
Username: Project6
Post Number: 8556
Circuit City, Best Buy, almost any consumer electronics store sell receivers.
Username: Project6
Post Number: 8575
Chris, you are making this way too complicated. The bottom line is, the Logitech X-350 is designed for the PC and it's contingent multi-channel analog outputs. It is not designed to decode signals from a digital source. The best you can get out of them would be matrixed surround, which is stereo that has been divided into the different channels. Another option is to have a DVD player that has 5.1 analog outputs or pre-outs. From there you can purchase an adaptor to connect the RCA jacks and the 1/8 mini plugs together. If you want surround sound you will have to buy a receiver and another set of speakers or a home theater in a box.
Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > 5.1 to digital optical adapter [ « Previous ] [ Next » ]
