Home > Message Board > Accessories > Remote Controls > Any remotes with RF database?
Author Thread: Any remotes with RF database?
Username: Toddious
Orlando, FL
I know that it is not possible to learn RF commands, so are there any remotes that have RF databases?
Username: Samijubal
Post Number: 2718
If what you are trying to operate is RF and IR, you can get a remote to operate it, I did with a satellite.
Username: Toddious
Orlando, FL
Post Number: 7
I"m asking for something that would be RF only, so that the user would not need a second remote for this device. is there such a thing as an RF database? like there is IR database?
Username: Samijubal
Post Number: 2722
The only RF only remotes I've seen were for satellites. They used to make a universal that was RF, but it only controlled satellites. What would the point of an RF universal? The One For All 8910 will control RF devices as long as they are RF/IR.
Username: Toddious
Orlando, FL
Post Number: 8
Well, we sell plasma lift mounts (the type where the plasma lifts out of a dresser, etc) and their remotes are RF only. So this always leaves them needing two remotes, on Universal Remote, and the remote for the lift.
Username: Samijubal
Post Number: 2724
I don't know if this is what you're looking for, but they advertise IR/RF.
http://www.universalremote.com/products/
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Remote Controls > Any remotes with RF database? [ « Previous ] [ Next » ]
