Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > 1/4" (or) XLR to S/PDIF??
Author Thread: 1/4" (or) XLR to S/PDIF??
Username: Alaskaworks
I was wondering if I could connect a keyboard with a 1/4 of an inch line out to a recording device with S/PDIF in. Currently, the keyboard's 1/4 inch out cable goes into an XLR adapter. So, is it possible to connect an XLR or 1/4 inch cable to a S/PDIF In (RCA style jack).
Username: Mixneffect
Orangevale, Ca.
Post Number: 992
Yes,
Just go to a guitat center or any musical instrument store that has pro audio. They have adapters from 1/4 mono, stereo, to XLR, and RCA.
Basically they are all low voltage un amplified cables. XLR cables are ballanced. The S/PDIF (Sony/Philips Digital Interface) is a digital to analog converter plug.
http://global.aopen.com.tw/products/mb/spdif.htm
Orangevale, Ca.
Post Number: 993
Read the indications on the website I pasted. It may not be a simple adapter install. There may be other equipment involved.
Orangevale, Ca.
Post Number: 994
http://www.webopedia.com/TERM/S/S_PDIF.html
Nevermind.
Looks like it is not a digital to analog converter. It just allows you to maintain digital to digital transfer without going to analog between transfer.
I should have done better research. I hope this helps. Google works:-)
Well thanks, but it appears that since S/PDIF is a digital connection, you can't change it to an analog singal (like an XLR or 1/4in) without going through hardware, like a sound card or the like. Anyone can correct me if I'm wrong...
Home > Message Board > Accessories > Cables > Archive through December 28, 2006 > 1/4" (or) XLR to S/PDIF?? [ « Previous ] [ Next » ]
