Thread: What kind of cable is best for video signal?? |
New member Username: Peterfm
Post Number: 1 Registered: Jun-06
| Posted on Saturday, June 03, 2006 - 03:54 pm: |
What kind of cable is best for video signal?? http://evisionplasma.ca/accessories-cables-c-45_51.html |
Gold Member Username: Samijubal
Post Number: 2666 Registered: Jul-04
| Posted on Sunday, June 04, 2006 - 11:21 am: |
How long is the cable run? Unless you've got a top end TV, a long cable run, and/or interference problems, you don't need expensive cables. |
Post Number: 2 Registered: Jun-06
| Posted on Tuesday, June 06, 2006 - 05:10 am: |
50-60 m |
Post Number: 2685 Registered: Jul-04
| Posted on Wednesday, June 07, 2006 - 02:18 pm: |
Is that meters? You're going to get some signal loss with a run that long. To go that far, you're best bet is to use the best quality RG6 cable you can find. |
Post Number: 3 Registered: Jun-06
| Posted on Wednesday, June 07, 2006 - 03:47 pm: |
Thank you for your help! |
