Home > Message Board > Accessories > Power Conditioners > How many devices can be plugged in?
Author Thread: How many devices can be plugged in?
Username: Musclez
Post Number: 8
I have a Panamax M8C-EX on the way. It has 8 outlets, but should I plug all my components into it? I have a rear-projection 51" HDTV, Toshiba HD-DVD player, Onkyo 6.1 receiver, powered 8" sub, and motorola dtc 6200 cable box. Is it ok to plug all of these into one strip? Sorry for the noobish question, but unfortunately I am new.
Username: Praetorian
Post Number: 160
You should not really worry about how many plug ins your strip has, but how many devices are going into a single circuit for your house's power distribution. Most of these circuits have either 15 or 20 amp breaker switches, some have 30, just look on the breaker that trips the circuit for your HT room (there may be more than one) and look at it, will display 15, 20, or 30.
So wattage = volts * amps
So, for most of North America your talking 120v per circuit, which means your looking at PROBABLY 15 * 120 = 1800 w, now we are not done yet... you should not exceed 80% of that number for total appliances wattage, so fudge it down to 1440. Now comes the fun part, add up the wattage of EVERY appliance hooked into that circuit (even light bulbs, use the max wattage for those, i.e. 40, 60 75, or 100). Your smaller devices like DVD players, tuners etc, prolly won't use a lot but your receiver, powered sub, TV will, just look at the back of them and read the specs plate, then add ‘em all up. If you exceed 1440, try finding another circuit to spread the love around. The easiest way to find this, is trip the breaker to your system's outlets, then run around the room with a lamp in hand and plug it in to all the other outlets until it works, then you found another circuit.
Hope this helps, and cheers!
Username: Musclez
Post Number: 10
Wow, been a long time since I had any electronics classes. That's exactly the answer I was looking for. Thanks!
Username: Hannjeff
Halifax, Nova Scotia
Post Number: 210
what would you do if your entire room was on 1 circuit?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Accessories > Power Conditioners > How many devices can be plugged in? [ « Previous ] [ Next » ]
