Thread: How to absorb 7-10khz only? |
Silver Member Username: Bvan
Cape Town, Copenhagen,...
Post Number: 106 Registered: Jun-05
| Posted on Wednesday, April 05, 2006 - 05:15 pm: |
i've got high frequency(>8khz) hearing loss in my right ear, and was thinking of using the tone controls on my arcam to boost the trebel(7-10khz so arcam tell me). The tone control cannot be applied to only one channel(can any amps do this?). So I obviously need to then kill this extra trebel on the left side somehow. What acoustical treatments might target this freuency range and without absorbing much bellow 6khz? I'm thinking maybe a very thin pile carpet, but i'm only guessing at what frequencies this might work. Thanks very much for any input. B. |
Relevant Product Info
Silver Member Username: Mixneffect
Orangevale,
Ca.
Post Number: 945 Registered: Apr-05
| Posted on Tuesday, May 30, 2006 - 03:10 am: |
To tame down tweeters, some people use fabric felt, like the ones you see on a pool table, or thicker ones that you see on the bottom of kitchen chairs. Glue some felt arround the tweeterlike a 2-3" dounut arround the tweeter, and see if that helps. |
Bronze Member Username: Willieman
PR
Post Number: 50 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 03:46 pm: |
