Home > Message Board > Accessories > Cables > Archive through March 25, 2006 > Anyone know where to buy coxial cable...
Author Thread: Anyone know where to buy coxial cable for cheap?
Username: Sal1976
Post Number: 15
anyone know where to buy coxial cable for cheap?
Username: Sal1976
Post Number: 16
I need a lot and the prices at home depot suck.
Username: Dodgedifferent2
Windsor, Ontario
Post Number: 90
wal mart?
zellers?
i have the tools to modify my coaxial cables.
Windsor, Ontario
Post Number: 91
ooops
i notice you need alot
how long are you looking for? 100 feet?
Username: Musicluvr
Post Number: 56
Sal,
What type of coaxial cable? There are many types. RG-6 and RG-59 are common types. If you are not sure of the type of cable, what is the application?
What length of cable do you need? Do you need 1 long run? Or do you intend to cut it up into pieces and terminate each piece with connectors? Do you need connectors?
Also, what would you consider cheap?
Username: Project6
Post Number: 7147
partsexpress.com
Username: Trilo
Spfld, MA
Usa
Monoprice.com great prices and cheaper as you order more.
Home > Message Board > Accessories > Cables > Archive through March 25, 2006 > Anyone know where to buy coxial cable... [ « Previous ] [ Next » ]
