Thread: Obscure problem with LCD TV, cables/leads maybe ? |
New member Username: Gort
Post Number: 1 Registered: Mar-06
| Posted on Friday, March 17, 2006 - 02:44 pm: |
Hi People. Trying to solve a problem I have with the screen, there's a intermittent black tearing affect that's got worse over time (only seems to happen when the set as warmed up). But the other day I disconnected all leads/cables from the back, for a hour, then plugged them back in, and since then the fault as disappeared Could there be some sort of build up in the leads causing the interference?
Post Number: 7119 Registered: Dec-03
| Posted on Saturday, March 18, 2006 - 08:44 am: |
Never heard of that happening before. You could be right that your connections were not very secure or there is some corrosion/gunk in the connectors. When you pulled them out, they essentially got a little cleaner. |
Post Number: 2 Registered: Mar-06
| Posted on Saturday, March 18, 2006 - 11:45 am: |
Thinking it could be the PC monitor lead plugged into the set,it as a choke? at either end, can they sometimes be dodgy |
